ExpeTillIDie
Ok so heres what happend...
I purchased a 2000 expedition recently, when it was purchased it was running perfectly... about a month later, i started smelling the sweet smell of antifreeze in the A/C, no big deal, i just need to replace the heater core...
So the other day im driving and it basicly dumps all the coolant and starts to over heat, i pull over and add water.
Then i check the oil and notice it is a little low, so i take it the next morning to get the oil changed, later that day it starts making a tapping noise, which i guessed was the lifter, due to the low oil. now yesterday it is not only tapping, but now it started to "rattle", which im guessing is the timing chain...
So my questions are as follows
does it sound like it is the timing chain?
do i have to pull the motor to replace the timing chain?
is there a good writeup on how to replace the timing chain?
do i need any special tools to take on this project?
should i just replace the chains, which i see cost around 50 each?
or do i need to replace everything with the kits that cost around 250?
im sure ill have more questions thank you so very much for everyone's help
