P0353 - Ignition Coil C Primary/Secondary Circuit
Description: See the description for DTC P0350.
Possible Causes: See the possible causes for DTC P0350.
Diagnostic Aids: See the diagnostic aids for DTC P0350.
P0350 - Ignition Coil Primary/Secondary Circuit
Description: Each ignition primary circuit is continuously monitored. The test fails when the powertrain control module (PCM) does not receive a valid ignition diagnostic monitor (IDM) pulse signal from the ignition module (integrated in the PCM).
Possible Causes: Open or short in the Ignition START/RUN circuit
Open coil driver circuit
Coil driver circuit shorted to ground
Damaged coil
Coil driver circuit shorted to VPWR
Diagnostic Aids: Use the 12-volt non-powered test lamp to verify START/RUN voltage at the ignition coil harness connector.
Check the coil driver circuit for open, short to VPWR, or short to ground.
