PO430 code and non start issue
alpine67
North Carolina
Hi everyone:
New here and have searched forum for other similar issues to the one I have. My wife's 03 Ex with 291,000 miles just died - I get only a PO430. Engine will turn over but not start. I have not checked for fuel or ignition issues yet, but wouldn't there be codes for those as well? Just curious if a bad cat would cause the engine to not start? Seems a little odd to me.
Wife indicated it was running okay prior to not starting, but had seemed to idle a little differently. She also said the check engine light had been on for some time.....
Any suggestions appreciated!
Thanks
George
Mediamonkey11
Super Moderator
Super Moderator
Enumclaw, WA
First check for fuel, try starting fluid. Also, is your security light flashing funny?
B
bedrck46
Guest
see if you can hear the fuel pump running Have wife turn the key to the start position without starting while you listen for the pump. Also check to see if the emeg fuel cutoff switch isn't tripped check for spark check to see if any fuses blew
A
alpine67
North Carolina
Thanks for the replies! If its the red led security light in the middle of the dash next to windshield, its operating as normal. I just checked the inertia switch and it wasn't tripped. Tried to listen for the fuel pump, and didn't hear anything, so tomorrow I'll look at fuses. In the event I need to dig deeper beyond the fuel system, are there any obvious ignition things I should check? I don't have a shop manual so don't know exactly where to check for voltage readings with meter.
Mediamonkey11
Super Moderator
Super Moderator
Enumclaw, WA
Easiest and quickest way to check for spark if you are doubting fuel would be throw some starting fluid in the throttle body and she should fire.
B
bedrck46
Guest
ford workshop manual on DVD can be obtained from seller "morpheousking" on e-bay cost about $10.00 much better than Clymer or Chilton and also includes wiring diagrams
Check fuse #34 also check to see if you have power to the shut off switch if you do and didn't hear the fuel pump run could be the pump is bad do as Mediamonkey11 suggest and if it tries to start then you most likely need a fuel pump
when was the last time fuel filter was changed
Check for fuel pressure
A
alpine67
North Carolina
Update on diagnostics: I'm getting power to the ignition system -with key on I'm reading voltage at the COP, albeit rather low (2.5 volts), due to a mostly discharged battery. I'm going to need to clean the terminals and charge it before I do much more. However, I did get into the fuse box and took some readings there, with ignition key turned on. At the Green/Yellow wire junction I'm reading 6.2 volts instead of 12, which I read elsewhere may indicate a relay (R303, not a replaceable part of the fuse box assembly, unless you're handy with a soldering iron!) going bad. When I checked the voltage at fuse 34 (PCM relay) I got nothing, but the reading at the light blue/orange wire was 11.6 volts so the pcm was energizing the fuel pump relay coil. At this point I'm leaning towards a bad relay solder connection, which apparently is not uncommon in these trucks, or a bad fuel pump. I'll know more once I get the battery up to full charge and repeat the above tests. I'll probably pull the fuse box and check the circuit board for burns around R303 since its easier and less expensive than pulling and replacing the fuel pump.
B
bedrck46
Guest
there was a post awhile back about the 303 relay and some pics and prints about it Its a solid state relay I see if I can find it and let you know the title of that post
B
bedrck46
Guest
check out this post
05 expedition cranks but doesnt start
A
alpine67
North Carolina
I have the PC board out and there doesn't appear to be any burn marks around R303. But looking on the back side of the board, there does appear to be one very minor cold solder joint for one of the relay pins. Not what I expected to find, so I may check the continuity of all five relays while I have it out and see if there are any shorts. I guess I'm back to searching for other possible problems, including the fuel pump.R303-1.jpg
PalosX
