pourus rims
dgray69
upstate ny
has any one every heard of alloy rims becomeing pourus, and loosing air due to chemical break down between road salt, and alloy, hmmmmm i work with alloy every day and never heard of such a thing, but this is the problem, i have been loosing about 5 lbs of air a week out of one tire, i have broke it down twice reset the bead, and changed valve stem, and continue to loose air, so today i took it to tire shop and they told my my air loss was through the rim, and the rim was no good, thought they were just trying to sell me new rims, but no go, got some comeing in a few months, just thought this was weird, never had alloy rims go bad, other than busting them up off roading
Black_Exhaust
Well anything with chrome or certain aluminum alloys breaks down with the brines and salts in the winter if they're not cleaned periodically. Detroit's built on salt and salt is built on roads. There's news reports on this sort of thing about twice every winter (I personally think that's far too few but, that's all I ever hear or see), one talking about Chrome wheels literally deteriorating under the finish to the point the rim collapsing on an 05 navigator. Different metals and metal alloys react differently to the stuff resulting ionization of the other metals in the alloy to the chlorine (might make the metal porous), or just corrosion. sounds to me like the shop's call on your rim should be legit.
mic_1011
yonkers n.y.
i've heard it's no good to leave chrome rims on in the winter because the salt is damaging to them. it causes the chrome to pit and peel. so i take my chrome whhels off in the winter and use the stock wheels. never experienced any problems. what you're going through is a first for me. but i guess it makes sense. especially if you've went ahead with all your other troubleshooting!
tonydiv
technical advisor
Middle River, MD
On one of my father's Grand Cherokee's there was one wheel that always lost air. I had the tire taken off and sprayed the inside of the wheel with Duplicolor bedliner paint. That seemed to do the trick.
jeff1998
Highland, IL USA
One of the rims on our old 99 Town and Country van did that. The lip deteriorated causing it to lose air out through the metal. You could watch it bubble on the metal. Traded it before fixing.
It is not that the metal "becomes" porous, aluminum IS porous. The problem is the outer "skin" breaks down and allows air to seep through. Some alloys are better than others but all cast metal has some, mostly microscopic, porosity.
dgray69
dgray69
upstate ny
yeah no shit, i drive by his house all the time and hes never home, hmmmm must be out mall crawling, lmao, sorry had to :) you go to jefferson univ, right, never even see your truck there, kinda looked a few times, im going to try the bed liner inside these rims, and then im hopeing to get a set of 36s for the new rims, think i might be able to get some from a club member from the syracuse off road club im in, fingers crossed,
henry98
niceville
ive ran into porous cast diff covers leaking fluid like a disease but never rims...ive seen chrome rims leak thru the chrome layer form flaking and cracking internally..but never just a porus cast alum wheel...weird stuff
walnuts4x4
Watertown, NY
yeah go to jcc but i usually park away from everyone... but as a matter of fact was doing some serious mall crawling today was sick!!! lol but actually expy is torn apart trying to put in headlights which is turning into a PITA cuz wanted to do something different than the way they were supposed to do but then snow and dark came so I put a tarp over it and driving dads grand cherokee...lol not fun working in snow when I'm sick as hell
dgray69
dgray69
upstate ny
im off tomarrow, sent you a text but you never responded, if you need help tomarrow let me know, im up for a road trip, call me if you want help
