Problem With My 2000 Expedition XLT
MOOOOOPS
New Jersey
For some reason, whenever I drive, my 4X4 light keeps flashing on and off when the 4X4 switch is set on 4AWD(not 4Hi or 4Lo). Also, when I turn in my car, the car jumps and jerks, but its fine driving straight. Very smooth. Do you know what the problem could be, and if its serious? Thanks for your help.
4x4Dude
Scottsdale AZ
When you say jumps and jerks, do you mean its like the engine is losing power than gaining it suddenly back causing a sudden engine burst of speed? or is the engine itself sputtering?
Does this happen every time you turn or is it just random? Have you had your transfer case fluids flushed lately?
M
MOOOOOPS
New Jersey
It doesnt feel like it has anything to do with the engine. It feels like the tires are "skipping" or "skidding" along the pavement
during a turn. The engine doesnt sputter at all.
Previously this would happen randomly, but now it happens everytime. I havent had the transfer case fluids flushed since I bought the truck(December 2006).
Senatordan
Yorba Linda, CA
If you turn off the 4awd and put it on 2wd that should eliminate the skipping in the turns. Then you can rule out anything else, but most likely something with the 4X4. I know on my dads Yukon if he has it on 4x4 Auto, that it skips all the time when turning.
4x4Dude
Scottsdale AZ
I'm going to guess Moops has the model i have where you don't have the option to put it in to 2wd.
Do you have stock wheels and tires on your truck moops or wider aftermarket ones?
M
MOOOOOPS
New Jersey
Correct 4x4Dude. I dont have the option for 2wd. The only options I have are 4Awd, 4Hi, or 4Lo. I have stock wheels and tires on my truck. And I just checked my tire pressure, and all 4 tires are at 34.
AvroAero
Toronto, Ontario
Sounds like the electro clutch is locking on the turns. Either one of the two speed sensors, or the computer. I've been told the program has a reflash avail but it never seems to help.
4x4Dude
Scottsdale AZ
Is this a common prob Avro? I take it if it never seems to help you experience the same issue as moops?
chuck s
I think the truck is in 4H, not 4Auto. The jerking is the tires slipping because the front and rear drivelines and differentials are locked together and you're getting driveline wind-up that slips from time to time. This is caused by a problem in the switch or electronic module that controls the choices for the 4wd system.
Is this 4Auto or 4All-wheel-drive?
My Explorer is always in 4Auto meaning the front wheels engage if the rears slip. Only choices are 4Auto, 4High, 4Low. I had to have the "module" replaced on the Explorer when the same thing happened.
On my Expedition I have 2High, 4Auto, 4High, 4Low. A much nicer system. When I switch from 2H to 4A I can sense the increased driveline friction.
-- Chuck
AvroAero
Toronto, Ontario
Oh crap I thought he said the A4WD light. If its the 4x4 light then yea chuck is right it may be stuck in 4x4.
Also sometimes the motor that engages 4x4 sometimes goes.
You had the module for the A4WD in your explorer replaced and you got results? I was told by a head ford tech whenever he tried it he never got any results so I didn't bother. Nice to know.
M
MOOOOOPS
New Jersey
This is 4AWD. Also, when I was driving earlier, the light started flashing on and off and the tires were jumping again, so I turned the 4X4 on to 4Hi for my ride, and when it was on, the tires never jumped. On my way home I turned the 4X4 back to 4AWD and on my first turn the tires jumped and about 5 mins later the light was flashing again. I plan on taking the car into my mechanic this week but until I do, should I just drive the truck in 4Hi? It seems to drive better with it in 4Hi but I dont want to ruin the truck.
AvroAero
Toronto, Ontario
Oh so it is in A4wd. Are the tires actually jumping or do you just feel jerking? I had the jerking problem and just disconnected the A4WD clutch completely since I don't have the 2WD option. Don't know why ford did that its pretty stupid. If you don't care about that feature you can do that to and it'll cost you about 6 inches of electrical tape. which is optional actually.
M
MOOOOOPS
New Jersey
The tires dont actually jump off the ground. I just feel the jerking. I probably will disconnect the A4WD clutch since I dont want the truck to jerk. If I tell my mechanic to do this, how much do you think it will cost me?
AvroAero
Toronto, Ontario
If you go under your truck and find the transfer case (after the tranny that has the two drive shafts connected to it) and find the wiring harness that goes to it. There will be one brown wire that strays from the rest of the wires. Cut it and tape it so it won't possibly blow fuses.
Free.
mbinky818
Just jumping in on this topic. I have the same A4WD. When you cut that wire, do you still have the ability to use 4h and 2h or does that disconect the switch completly?
AvroAero
Toronto, Ontario
That just disconnects the A4WD. 4WD (and 4low) and 2Hi have a separate motor to engage. I've done it to my truck.
M
MOOOOOPS
New Jersey
Just 1 more question. If I cut the wire that disconnects A4WD, what would I be driving in for regular everyday driving? 4Hi, 4Lo, or 2wd?
