Radiator Cooling Fan Running at High Speed in Cooler Weather?
2015owner2015
Northern California
Recently my cooling fan kicked in to high speed (loud) when the outside temperature was relatively cooler. The two times this happened once it lasted for a couple minutes and the next 15-20 minutes. Typically it only kicks in when temps are 90 degrees or higher. Temperature gauge was normal and no codes.
I did change the coolant at 100K mileage and I just hit 150K. What are some typical causes for this? Obviously I will check the coolant level, but anything else?
Thanks!
adamsdaddy
Orange County
You already know to check the coolant level. When it got a little low, turbo airplane fan was kicking on all the time and the Expy wouldn’t warm up the interior of the Expy.
