Ready lift 2" rear vs rough country rear spacer
22timberline
califorina
So originally I bought a used Readylift 3/2 lift off ebay. I actually re machined the front puck to be half thickness so I can get a 1.5"/2. Then I ordered the rough country control arms and ended up getting the rear spacer from them too. They didnt want to separate it so whatever. But now im looking at the spacer sided by side and they are massively different. The ready lift is the just the fabbed spacer on the left. But the ready lift spacer is larger AND they want you to shim the spring too. Its literally twice as much spacer.
Can anyone chime in on the rough country kit? Did you install the spring spacer? How much lift did you get?
Anyone install just the ready lift rear? How much lift did you get? This is baffling
2nd pic is my remachined ready lift spacer. I ended up putting knuraled studs instead of threaded since there wasnt enough material left
The Ragin Cajun
CA
Hey @22timberline - Wanted to check in on your Timberline's suspension. Have you found the right voodoo to give it a level, 2 inch lift? I am also looking to add twoish additional inches to stock Timberline and 285/75/18 KO3s to give me more ground clearance and better grip.
