Real or Fake?
panda24619
San Diego
im going to say realy fake. just like pam andersons boobs. haha but who knows. for $10 i would buy it.
jacks3am
michigan
hell yes its fake. anything like that is bs. if it were true everyone would hve one
KWT2000
NINE MILE FALLS
all it does is tell the ecm that the intake air is colder than it really is... kinda of the same idea with running a colder T-stat
SOLISIMO
Ft. Lauderdale
Its the same as those ********* chips they sell, these guys just market it better. Plus its bad for the motor
junior73
South Carolina
In theory, it would work, but not the way you want it to. The ECM bases fueling and spark on the air temp and the coolant temp. Just because the motor see a cooler air charge, if the water temp is still past the flag for what the ECM considers warm, the timing and fueling won't be affected. The cooler T-stat works better at fooling the ECM because if the warm flag for the motor is lets say 180, and you have a t-stat set for 160, than the ECM will keep the motor in the "warm start up" mode, giving more fuel and spark. The downside is, when you're just cruising, instead of the ECM going into closed loop to allow for a leaner burn since you're not putting a major load on the motor, you're just burning away fuel that you don't need to burn.
In short, all these types of gimmick are just that, gimmicks. Yes, they give you some negligible benefits, but in the long run aren't worth the time or the $10.
Caveat= All of this information is based on what I know about how the EEC-IV's work, specifically Fox and SN-95 Mustangs. The expeditions might be slightly different, but I doubt it would be enough for me to think any differently.
Keith
SOLISIMO
Ft. Lauderdale
Keith
Even in theory its not good for the car. Fooling your computer to do something your car really isnt doing isnt a good thing:jester:
Interceptor
TX
To put things in perspective, resistors cost about 15 cents each. Doing a google search, looks like a lot of people have been taken to the cleaners.
Racenut
Deming, New Mexico
FAKE!!!!! Why would you even consider it when your Edge will do more for the Expy than that POS and will do it safely.
offroadexpy
Dont do it
I installed one on a 03 f150 some years ago, the truck wouldnt even run afterwords. I had to remove it to even drive it. DONT WASTE YOUR MONEY or your time.
ScottyDsntKnow
NJ
Snake Oil
File this in the same category as the Tornado and Electric Superchargers.
joezek
psl, FL
That's a pretty old scam that I can't believe is still allowed on ebay. There's just no way possible to get 20 hp out of tricking the computer to dump out more fuel than normal. You'll be lucky if the check engine light doesn't come on. Usually the tuners get a little bit more hp by slightly leaning the fuel mixture at WOT, by removing the factory designed safety margin of overly rich.
panda24619
San Diego
It's just a resistor. Turned my check engine light on. No hp gain
Ford Intake Sensor Performance Mod adds up to 20 HP (#280654047985)
Detailed instructions, Fast shipping, and Great communication! Thanks A+++++++++
Add 20 more Horsepower- Ford Intake Sensor Mod (#280653883361
not what i expected but nice job scamming its my fault for buying it though
Add 20 more Horsepower- Ford Intake Sensor Mod (#280646763906)
great product great transaction great seller A+
Ford Intake Sensor Mod 20+ HP (#280636739489)
very bad instructions!!!
Ford Intake Sensor Mod 20+ HP (#280650100873
i hide the buyers names. but like really? dont buy it 1st off. and 2nd really? it worked? come on now!
