Rear camera install
01exp4x4
Nashville
Its a Crime Stopper SV-6818.EM.II
Cost $31 dollars from sonic electronics.
Installed it along the stock wiring harness to the license plate lights.
NOW... WHERE IS THAT REVERSE WIRE!????????????????????
B
bedrck46
Nice install
Had to wait till the end of the pics to find out its on a 2003 your forum name had me fooled for a bit
01exp4x4
01exp4x4
Nashville
Thanks,
sold the 2001 that I had, now I have a 2003...
I would change the screen name to 03FX4 if I could...
Don't know how
01exp4x4
01exp4x4
Nashville
I did peel it back, seen here:
I used the heat gun to re-apply the glue after...
Resjudicata
KC
I know this is an older thread--but, there isn't much info on how to wire these reverse cameras.
What path did you use to run the wires from the rubber grommet between the tail gate/body to the front of the truck? Did you just fish it along above the head liner? Or, above the doors?
Thanks,
Chris
Spooky
I ran mine through the plastic running on the Driver's side. It was by far the easiest route. Plenty of space to get my hands in there and run the cable.
Trueblue95GT
Bethel, CT
Is there a way to hook up a backup camera to the factory Navi head unit? There was a device on our old X5 that sensed power from the reverse lights and automatically turned the head unit to an aux in.
drokmofo
southern az
depends what year you have. loc pics seem to be the easiet. I have an 07 and they only seem to go back to 09 w the loc pics. 5 yr rolling manufacture cycle maybe? I found this w more than a couple suppliers.
I had to go w navtool. had to remove head unit and ship it to them for internal mods. they ship it back and then u install. comes back w a small box wired to it w 2 ground leads ( 1 is for parking brake), 1 12v accessory power lead, 12v reverse power lead, and another for a push button toggle switch(like a valet switch) to switch between vid 1, vid 2, and factory screens. vid 1 can b a forward cam or dvd in. I just got mine back and am prepping for the install. also got a factory looking cam from rearviewsafety.com it replaces the driver side license plate light but includes a light and camera in 1 small housing. that comes in tomorrow.
I have been searching posts for where to find accessory power to bring to the head unit and reverse as well. easiest?
Alansd
Georgia
My 2006, new to me...came with a DUAL Stereo, touch screen and a bckup camera over the license plate. The camera is not working though the reverse sensor is ..
what should I troubleshoot? The power hook up? Seems like it goes up through the tailgate somewhere.
ezeq
canada
Check the power going to camera, also check for continuity. Use a DMM.
