Rear Climate control tech questions
joezek
psl, FL
On the 2003 expedition, electronic climate controlled, I've got a few problems. It has the common popping from both blend actuators.
However when I manually by hand, rotate the temp control door from hot to cold position using a wrench, the cold air is average room temperature. Also, the hot water pipe/hose is 190 degrees all the time. Shouldn't there be a valve to shut off the hot water when it's in the "cold" position? I think this could be a reason for not getting cold a/c in the rear. The rear expansion valve gets ice cold and sweating, but the air isn't cold. When manually changing the temp door to hot, I get hot air, but on cold, it's warm air.
joezek
joezek
psl, FL
No one really cares looking at the lack of any responses... however just an update for you guys/mechanics like me that appreciate seeing a problem solved.:
- I replaced the aft a/c system expansion valve an it completely solved the problem. Aft a/c is freezing ice cold now.
- found the part number using partstrain or something like that, searched ebay and found a brand new surplus Motorcraft expansion valve for $12 with FREE shipping. List price is like $68 for that valve.
