Rear Lower Shock Bolt Torque
Raven_Expedition
Huntsville, Al
I did a quick forum search and didn't see an answer to the question. Chilton's is pretty much useless. I did run across a 330 lb-ft value that seems too high. Can anyone weigh in?
Thx-
1955moose
We had this discussion about 2-3 weeks back. I believe it was 295 ft pounds. Your going to need a 3/4 inch breaker bar, and tighten with a good pull. Ideally a 3/4 inch drive torque wrench, but that's pricey for something you won't use again. Another member suggested a 1/2 inch drive breaker bar with a cheater pipe on handle. Bottom line, just pull on handle hard, your not going to break a bolt that big. If it was me, I'd recheck tightness about a week after first tightning.
Adieu
SoCal
Different years list different specs for some reason... but basically you need a 2' breaker bar and lean all your weight into it, between 3/4 of the way and the very tip depending on your body mass
