Love it. I turned mine into a camper but didnt go THAT far (removing rear panels). Can't keep my 2014EL cool in Nebraska in August without rear cooling but it is still more comfortable than the Lewis & Clark Expedition had it. Ha! EXPED Megamat makes a great bed.I'm turning it into a camper. I'll be driving around the country with it and won't be in FL when hot. Also, I will have a 5k BTU AC in the back. I just want to remove it for the added space.
The heater water lines should also be plugged up front.
That'll work.I was just going to recirculate them at the back and later hook them up to a heat exchanger.
That'll work.
space and weight savings imo is not worth the squeeze and cost to evacuate and recharge the system.
you said you have a 5k btu ac in the back??? back of what?
but hey its your rig. do what makes you happy.
ok...cut a hole to install an ac unit, but you are taking out the ac unit from factory. use the rear one when parked in a campground i guess,
i anticipate the end results of the job . you have a good bit of work to go. hope it goes good for you
