For clarity, the 18-21 is not the same as the 22+. That being said, the 21+ Raptor wheel should be plug and play in the 22+ Expedition. You will use your buttons in your current wheel.Yes.
Raptor Steering wheel on 2021 Expedition Platinum.
So I just fitted a 2019-2020 Raptor steering wheel with paddle shifters to my 2021 Expedition Platinum. I can confirm direct plug and play. Only adjustment I had to do was swap out the right side raptor wheel controls with the Expedition ones and they all work with no rewiring needed. So for...www.expeditionforum.com
Good catch, my mind didn’t register the model year. Process should be the same as the 18-21 models.For clarity, the 18-21 is not the same as the 22+. That being said, the 21+ Raptor wheel should be plug and play in the 22+ Expedition. You will use your buttons in your current wheel.
What do you mean by "wire in"?I swapped mine over a few months ago, you’ll have to use your stock steering wheel button clusters and wire in the paddle shifters.
Where did you get your raptor steering wheel?I swapped mine over a few months ago, you’ll have to use your stock steering wheel button clusters and wire in the paddle shifters.
I’ll rephrase that, most of the Expys don’t come with the paddles shifter wiring in place. My 2021 had it but my 2023 didn’t. If the paddles don’t work after install the wheel you’ll have to run 3 wires from the main plug for the steering wheel down to the manual shift buttons on your console. Very simple harness to make. Google “ford f150 paddles shifter wiring” and there’s a few write ups.What do you mean by "wire in"?
eBayWhere did you get your raptor steering wheel?
I think the SPP should have came with the Raptor steering wheel.Holy buttons. Did they just move the buttons from the pre-tablet center console to the steering wheel?
You have to swap out your buttons from your existing steering wheel.Does this get you a play/pause button on the steering wheel?
I hate that my 2023 Platinum Max doesn’t have play/pause anywhere.
I just put mine in, and it didn’t work. Did you ever find a solution?Has anyone been able to get the boosted grey goose f150 harness to work for this swap?
