bigmann245
04 expedition Eddie Bauer 5.4L
I had the blend door actuator clicking issue so I replaced both actuators. I fixed the clicking issue but realized the rear ac only blew hot air regardless of the temperature setting on both front and rear controls. I removed the actuator that is mounted on the side of the ac system and took the gear and spline out of the old blend actuator and manually moved the door myself. The temperature responds to the manual turning the door just fine. The new blend door actuator doesn’t seem to respond to the control panel settings to change the temperature using either control panel. I bought it from autozone, could it be bad or possibly the wrong actuator? Originally I bought a set of 2 from Amazon and had the same issue so I decided to just not be cheap and buy one from a local parts store but neither actuators changed the temperature. I zip tied the door in the cold full open position because it’s Florida and above 90 all the time. But when it gets in the winter months I would like to be able to adjust the temperature as needed in the rear system. The front system works perfect it’s just the rear I’m having issues with.
I recently replaced the fuse panel to repair some other issues and used all brand new fuses and relays but I checked the ones for the ac system anyway and they are good.
The fan speed does respond to both front and rear control panels if that helps, just not the temperature.
