Rough Idle???
spank 141
cali
Whats up everyone new to the expedition world. I have owned several ford trucks and currently own 3 mustangs. Anyway I just got a 2002 expedition and installed a K&N cold air system and flowmaster catback. The truck was completely stock. So after a test drive and a drive down the freeway when I pulled off the truck started idling really rough and the check engine light came on. I don't have anything to read the check engine light with. I have installed several CIAs on my past trucks and I have never had a problem, but I went back and checked everything and I don't see anything hooked up wrong. Is there anything I need to adjust on a expy such as the idle??? I will be changing the fuel filter tonight and the oil was just changed. Any suggestions are appreciated.
Stoned06
Milwaukee
Just replacing the CAI should not affect anything. It could be a coincidence like a COP going bad, or you might have a loose vacuum line. Get the codes pulled at Autozone or Advance Auto (or the like) and that will give you a good place to start. Good luck.
S
spank 141
cali
thanks for the info. I was thinking maybe a vacuum leak after I posted that. I didn't see a crack in it but I didn't take it off either my ford dealer has to order the part.
Blackwater
Maryland
Im putting up another post close to this one. Subject po306.....Check in on it!
S
spank 141
cali
replaced elbow with new part no help. I inspected to old one and didn't find anything wrong with it so I didn't think it was going to help. The idle is all over the place. I don't see much wrong with acceleration. Checked as much as I could for other vacuum leaks and could not find anything. Any more suggestions?
sparkone
Louisiana
Did you get the vacuum hose right behind the manifold? The one the guy's showing is for a 98, the 2002 is right behind the throttle body, running along the back of the firewall. I wet to Autozone, got a piece of 3/8 vacuum line, needs to be more than 12 in. and connected it straight, and put some hose clamps on instead of the lil green plastic elbow that is there.
S
spank 141
cali
I got the same one that is in the picture of the link from above that included the pvc valve and the plastic tube. I see the hose you are talking about right out the back of the TB. Mine is in pretty bad shape starting to dryrot. I will run down to autozone and grab some hose and replace that one tomorrow. Is that just another vacuum hose?
sparkone
Louisiana
yep,change the pcv valve while your there, have them check for misfires, change plugs and cop's if their misfiring, then pull up in front a church and pray!
Condog09
Minnesota
Did you get chance to run to auto zone and pull the codes and if you can have them let you look at it and record the short term fuel trims and long term fuel trims and if you can only get one get the long tem fuel trims. That will tell you if you have a vacuum leak or if you have another problem. You can tell A LOT about a vehicles drivabiliy problems witht the fuel trims and codes. Thanks!
Eric
California
Would be interesting if you put the stock air intake back on to see if any change. Outside of knocking a plug or vacuum line loose seems very coincidental that this would happen at the same time as the work you did on it. Did you put the CAI on before the cat-back and if so was it running fine at that time? Was the battery ever disconnected during this process?
phillip mac
Tuttle, OK
Is it possible that you have a misfire ?
You could possibly have a bad coil pack or possibly time for new plugs.
