bostonshouse
Glad to be part of the forum and hopeful that someone can help with my issue. I have a 2006 expedition limited. It was running fine normally but had an intermittent issue with a slight miss under load which threw a code for a coil issue on the number 3 cyl. I replaced the coil and the issue went away almost completely. I decided to let my local shop replace all the plugs. That is where the problems started. The expy now idles terribly with a noticeable miss. It improves under acceleration. It is not throwing any codes and the shop is stumped. The rough idle is noticeable in park and neutral but really bad when idling in gear. Problem started immediately after having plugs changed. Any ideas?
