Rumbling noise on turning 2017 exp LTD EL
Cynthia2963
Colorado
My 2017 expedition makes a rumbling noise on turning, either right or left. Had tires rotated and alignment done. Still rumbles. Any advice?
16plati
VA
Mine rumbles upon slow turning left or right after it sitting overnight. I believe it is my tires being that they are 35s with a wide stance and they are basically being pushed during turns due to change in suspension geometry from my lift
16plati
VA
wheel bearings?
Not for me, just had the fronts replaced last year with IWEs. Like I said, I’m getting wheel vibration from the wider stance and the truck is pushing the tires while they are trying to roll forward. It’s all from the Ackermann effect
LokiWolf
Moderator
Richmond VA
My next thought is that the front is staying engaged in 4WD even though the center is not. Thinks it’s not in 4, but front still is. Simple way to tell would be to lift the front up, spin a wheel and see if the opposite or front drive shaft spin.
16plati
VA
I’ve tested this on mine as well. Truck up on jacks, turn on, 2WD, tires both spin and CV axles stay put. Turn to 4WD, spin tire and CV axle spins with it. Normal operation, correct?
Plati
This is a bit of a stretch, maybe not even viable? You say its not in 4WD meaning the switch isn't in that position and the status lights don't say its in 4WD … but maybe something malfunctioned and it really is? If it always "rumbles" while turning either direction, is it the outboard front tire scrubbing because its stuck in 4WD? Any way to test that? A slow sharp turn on pavement? Maybe then put it in 4WD and see if its does the exact same thing?
OK .. its a l o n g shot
edit: I guess that's what Loki said a couple posts back, I missed that
LokiWolf
Moderator
Richmond VA
No. If both wheels spin when you spin one, the hubs are not unlocking. That is your issue.
Nevermind, you said CV stays put. If both wheels in 2WD spin independent of each other your Hubs are working.
16plati
VA
Yup engage 4WD and they lock to the wheels
16plati
VA
Funny you say that bc I did just that yesterday with a buddy. Found a parking lot, 2WD, full turn left and full turn right, both times the CV axles stayed disengaged from the wheels and operated normally.
16plati
VA
Alignment was done yesterday. Didn’t help.
Have you greased the little bump stops on the lower control arms? They are actual bumps that when you go full lock they will tend to rub on the little pockets they fit in to
16plati
VA
Update on my rumbling..
Found a tear in outer tie rod ball joint rubber. Probably starting to rust and get a bunch of grit build up in there. Will re update when fixed if that’s the real issue
Captain Kirk
Pittsburgh
It sounds like its your rear end. The limited slip clutch packs are binding a little. Mine does it every morning. When I leave out of my driveway it feels like the rear axle is locked. I have read that you can ad a "friction modifier" to the rear gear lube and it will solve the problem.
