Rushing air sound under normal acceleration
JerEazy
Sarasota, FL
‘17 EL with 3.5
Under normal acceleration I hear this rushing air sound in the cabin. Almost like a road noise kind of sound, but predictable with acceleration. And happens regardless of speed.
If I push the pedal down 1/2, 3/4 or floor it, no sound. Lightly press no sound. In neutral also no sound.
A few searches say MAYBE the wastegate is leaking letting air out. But, being I’ve never driven another EcoBoost I have no comparison. So, I figured I would toss it out and check with the experts!
Thanks!
Adieu
SoCal
The "whoosh"? My 5.4 SSV did that
Idk, either dented exhaust (cause that's definitely dented on that truck) or Expy lacking sound insulation... Gator 5.4 doesn't do it, at least not audibly from cabin
J
JerEazy
Sarasota, FL
I don’t think a dented exhaust would be the issue in this case.
It’s tough to describe the sound. Like making an “O” with your mouth and exhaling hard hahaha
Adieu
SoCal
Oh yeah remembered something now...
Replacing a heater hose with a near-negligible pinhole leak, new thermostat, and coolant backflush seemed to help a bunch I think?
J
JerEazy
Sarasota, FL
I have an appointment at the stealership on Thursday. I just don’t want to make a thing about it with them if that’s normal for the 3.5tt
J
JerEazy
Sarasota, FL
I agree. But it doesn’t make the sound (that I can hear) if I have the engine in neutral.
Adieu
SoCal
Crap seals?
Do you hear it going downhill without pressing the gas pedal?
J
JerEazy
Sarasota, FL
Not sure - not a ton of hills here in Southwest Florida! Haha
But there’s a steep overpass nearby I can give a run at tomorrow.
Muddy Bean
If it’s making the woosh noise and then kind of slaps shut and stops making the noise it’s definitely something in your turbo/gasket/wastegate. Mine made this noise until all were replaced and it doesn’t now.
Adieu
SoCal
Mine made it and it doesn't even HAVE a turbo though
Muddy Bean
Lol. Maybe it wants to be an Ecoboost so it’s copying Ecoboost sounds lol
jimz
florida
Not sure if this is even close but I had air noises (no ecoboost). I was searching everywhere for that noise but no luck. What solved the noise for me was running the A/C fan on second speed to build cabin pressure. This kept the air leakage going out instead of in and stop inside noise.
After looking closer at rubber gaskets and seals that would allow airflow I notice how gaskets around door were shorter than they could be to completely seal edges. The outside side window gaskets that should be touching glass have about a sixteenth of an inch gap that not only allows air flow but also water to fill doors and damage actuator mechanisms. A combination of these design issues, in my mind, allowed air flow that created noise. The build up of internal pressure caused noise to flow out with the air, maybe. But for whatever reason I have a quieter ride now.
J
JerEazy
Sarasota, FL
Well at least it seems this is not correct - so I’ll make a deal about it while it’s in the shop.
Fingers crossed for free replacement parts!!
Minnesota
Is the defrost blowing air? With my 1999 superduty 7.3 powerstroke this happened when the fourwheel drive system was leaking air. The blower would default to the defrost mode.
J
JerEazy
Sarasota, FL
No. I’ve turned off the AC and radio to hear it better.
It’s reoated to the gas pedal for sure. But then also load related. Put it in neutral while rolling down the road and feathered the gas and no sound.
txracer16
League City, TX
From what you are describing it is normal. You hear it more during light to moderate acceleration and lower speeds? The sound is more than likely coming from the intake plumbing due to the bypass valve on the pressure side between turbo and throttle body. Completely normal. One of the ways boost is controlled in ecoboost engines is to bypass boost back into the fresh air side of the intake system. It’s main function is to reduce turbo flutter on deceleration but can also be used to control boost. Boost is controlled by the wastegate, throttle plate, and bypass valve all working together. The use of all three is what gives the ecoboost the smooth power delivery. A lot of times it is actually using the throttle plate and bypass because they are electrical and can be operated faster than the diagphram actuated wastegate. Reason you don’t hear it in neutral is that there is no load on engine, won’t build boost without load.
Of course with out hearing it personally can’t say for sure. Mine and every other one I’ve driven has done this. A lot of people don’t notice it. Hope this might shed some light. EB is an awesome engine.
J
JerEazy
Sarasota, FL
TXR you literally said almost verbatim what the tech I took a ride with today explained. He also warned me that if I put on a CAI it’ll get louder.
Glad to know it’s normal - it’s just not what I’ve heard from my other turbo engines.
For the rest they did a great job of meeting my requests. Sadly the “rubbing” sound I’m hearing at lower RPMs is likely the beginning of a failing bearing. He said it’s not far enough along to warranty yet - but I’m loaded in the system.
lbv150
Northeast
Hmmm. Could it be coming from the speakers? On some models Ford pipes engine sounds through the speaker system to give the passengers a sense of engine power...
I thought that was only with vehicles that had Subwoofers as part of the stereo!
