Safety Recall 22S36 - Certain 2021 Model Year Expedition and Lincoln Navigator Vehicles - Underhood Fire
ManUpOrShutUp
PA
Yup, but there shouldn't be failures of any kind in a perfect world.
That's a very black and white view you have. On one side it's a perfect world and on the other it's fine that $80k+ trucks spontaneously combust even after being parked for a day.
Fastcar
FL
No, more of a realistic view. Stuff happens whether it's a 80K or a 30K item, in this case it is reportedly less than 50 that have had an issue. We are not talking about a large number, of course to the individual that owns the truck it is huge.
Rob6805
Ford says that there have been 16 fires so far. Yes, that is a very small percentage of the total built. And also why it's difficult to determine the root cause.
mrmustang
Greenville, SC
Pretty lame that Ford can't figure out what is causing the fires. And I wonder why it doesn't impact the F150's with the same powertrain too? Something unique to the Expedition/Navigator.
While you consider it lame, you have to figure it could be any number of issues, from a part coming from a 3rd party supplier failing after "X" amount of time or hours used. It could have been a faulty sub assembly from that suppliers, supplier, or further down that food chain. A simple .0003 of a gram of solder on a microchip, which is now failing because of vibration or heat degradation. Perhaps all of the parts and assemblies are correct, but a person on the line was mis-trained, or his/her installation equipment was out of spec. Perhaps a forklift driver let his/her pallet down too fast, thus jarring the parts in such a way as to cause issues days, weeks, months down the road. Perhaps a tractor trailer driver hit a large pothole while taking a batch of parts from another manufacturer, or perhaps this is just something that was never considered when the truck was being designed (not likely, but still possible). There are 100's, if not 1,000's of other things that can be at fault. Finding them is not the trick, and Ford, I am certain, is throwing a millions in liquid funds to try and find and fix the issue so that it does not occur down the road ever again.
Just my two cents worth on the subject.
Bill
Fastcar
FL
Bill
Agreed with all of the above. But, Ford has managed to determine what trucks in the Q could be affected. That would lead me to believe that since they have managed to determine the hard start finish production dates they are aware of what is causing the problem.
dnprall
Minnesota
We found out about this on 5/19/22 and parked the truck outside. 30 minutes later a hail storm with ping pong ball size hail came through! FML.
Rob6805
Bill
Yes, all true. But somehow they know the production date range of vehicles affected. They have to have a clue as to what's causing this. My bet is that the fix is not easy. Maybe involves removing the engine to access. Or possibly the IP. Both of which are very time consuming and present a risk that things are not reassembles correctly. They are crunching the numbers to see what, if any, solution is financially viable.
PHD20
NC
Not sure if it could be related to this, but has anyone else noticed their Expedition making random noises while not running? Even when it's been off for several hours, in the garage, no one is touching it and the key fob is no where near it, I will sometimes hear an electric motor sound for about 2 seconds. Any ideas?
twinturbodude7
NC
I have a 2007 4runner that does the same. I think it's related to the fuel evap system / leakage check.
ROBERT BONNER
Denver, NC
Bill
Bill:
All correct, then add to it that:
1) The subject vechicles have been completely destroyed. Consider the forensics of just electrical connections: House fires that are started at electrical connections or appliances will normally have several feet of separation between discrete suspect appliances and/or connections to be investigated. Under the hood of any modern vehicle, the separation is millimeters. There are thousands of suspect connections and devices, that are all scorched and melted together. This doesn't make the task impossible, just more challenging.
2) Ford's access to suspect vehicles is usually mired in legal turmoil while the burned remains are left to corrode in a salvage yard or impound lot. Frequently the NTSB and NHTSA have first access to the vehicles after the attorneys and local fire investigation authorities. The people assigned from those various organizations have neither the expertise, knowledge, common sense or basic intelligence to know where to start, not to mention the damage to the forensic process that they do either intentionally or unintentionally to the involved vehicles long before Ford is allowed to review the vehicles. Having a vehicle experience the thermal event while being operated by a Ford Employee, at a Ford facility, or at a Dealership constitute a lucky break for all involved because it normally speeds the process by months to years.
In fact, the time that it took for Ford to get custody of the first vehicle(s) probably explains the lag between these specific events and the official notice to customers of the suspected problem.
Just saying.
