YeahDoggie
Hello, I have a 2004 Expedition with the 5.4. It was recently stolen. When I got it back, the steering column was pretty mangled. I purchased a used column with key from a reputable source and installed it without much issue.
I have not bolted it all the way in, as I wanted to make sure it worked before tightening everything down. The only thing not hooked up, is the gear indicator. Mine was cut, the new one was also, I have to figure that out too. I dont know if that makes a difference.
When I hooked up the battery, everything powers up, all the switches on the column work, but i cant get the starter to engage. Im 99% sure this is a security system issue. As soon as i turn the key to the ON position, the red security system light on the dash blinks fastly.
Is there any way to bypass this? or what steps do I need to take?
Any info would be much appreciated.
Thanks In Advance!
Thanks In Advance!
