Shakes violently while braking
tilliepeople
Madison
My 04 shakes violently when braking especially at high speed when the need to slow down takes more peddle .This stops the moment you let off the brake .
This feels different than when I had a stuck caliper and it would not stop shaking after you let off the brake
It drives great and follows a straight line if you take your hand off the wheel so I do not suspect suspension or steering parts .
I do not want to just throw parts at it so I thought I would get some opinions first.
Thanks
Bill
HawkX66
Semper Fi!
VA/MA
Do a search for my thread. "You don't have Warped Rotors." Might help, might not...
T
tilliepeople
Madison
I have been thinking brakes and rotors
This actually started after I replaced a caliper and I suspect it may have warped with the old caliper and just got worse .
I have only had it for about 1 year and have replaced the trany,and brakes but not the rotors .
Hamfisted
Ft Lauderdale
Yeah, if you've had to replace the tranny already I'd bet it was used as a tow vehicle for something heavy.
T
tilliepeople
Madison
Trany rebuild was from no overdrive.
Once they got inside they found damage from the servo and had to replace extra parts
Works good now
TobyU
Ohio
You don't need to inspect anything. Put 2 new rotors and new pads on it ans it will be smooth as ice again.
johnboneske
Ohio
Don't forget to tighten all the lug nuts the same, most people think overheating rotors is why they warp. They do warp from overheating, but the #1 cause of warped rotors is uneven ft lbs on your lugs!
RichardH
TX
Interesting point and it makes sense.
JuniorExp03EB
Chicago, IL
very well possible for wrapped rotors due to uneven torque specs. always star pattern and torque to spec check 2x. and your set. keeping everything in aligment will also help
Sent from my SM-N960U using Tapatalk
RichardH
TX
The 'new' vented rotor. lol... I can't imagine going this far on brakes w/out throwing a piston.
OP: I hope the issue is readily solved via new rotors/pads. Go ceramic (pads) if you can. I have had great results.
johnboneske
Ohio
I have never seen a rotor like that, where did you find that picture? Can you imagine actually using some like that? Would never stop!
RichardH
TX
I just stumbled across some like that one recently when researching rotor issues for a friend. (google 'worn car rotors' and you'll find a few other examples).
I hope the OP can chime in with the fix for the issue they were experiencing...
JuniorExp03EB
Chicago, IL
im surprised this thread is still active for a brake issue [emoji85]
OP Whent awol lol
RichardH
TX
Lol...
OP will come back to update.
Late Braking err...breaking
TobyU
Ohio
I have pulled two off that were into the fins like that. They are actually not nearly as rough as you would think. The owners were still driving along.
NOW the BEST was a 79 Thunderbird that I bought in 1993. When you hit the pedal it felt like the rear right tire was coming toward you!
I pulled the front wheel and the rotor was in TWO PIECES!
There was a piece of metal that laid against the rotor right outside of the hub and studs and acted like a lathe and cut it in half.
The complete disk stopping area with no extreme wear or grooves was hanging there a little sideways and not spinning at all...just the center hub and studs were spinnning so that wheel has ZERO braking action.
no noise at all at that point but it sure felt funny.
