I'm looking at doing the 3/2 spacer lift with the extended sensor links for CCD. What are you all doing for tires on the 22" wheels? I typically like more sidewall but do like the looks of these wheels. I'm thinking the Toyo A/T3's or the Falken Wildpeak A/T3W.
I’d ditch the 22s if you plan to off road at all.
Mike do you have a link / source for said springs ? Saw the video, your truck is exactly what I'm going for. Great job !I also installed custom rear springs that are 25% stiffer and 1 inch taller.
Which 5100's are you using? How much lift did you end up getting and how about some info on the springs pleaseView attachment 41651 View attachment 41652 View attachment 41653 View attachment 41654 I put Bilstien 5100 all the way around with fords latest revision of spring which has a bit more lift. I am running Fuel 20s with Goodyear ultra terrain tires. It’s plenty high enough for me and the electric running boards actually have a purpose now.View attachment 41651View attachment 41652View attachment 41653View attachment 41654
Any update on this???Here are a few pics of my '16
My friend made a nice video about the truck HERE
Currently lifted with spacers - its the only bolt on option I've found.
View attachment 68886 View attachment 68887
Currently gathering parts for a Raptor front suspension kit and custom 5 link on the rear with Fox 3.0 Racing coil overs.
Should be about a 3 inch lift from stock with 12 inches of travel front and rear.
Will update when that project is done. (Hopefully!)
Baja Kits Ford F-150 Pre Runner Kit
Fox Raptor 3.0 Internal Bypass DSC Coil Over
The money pit never stops - But it sure is fun,
Mike
