Show your Lifted 3rd Gens
can16fan
Maryland
Just completed this upgrade on my old 2007 Expedition XLT.
3" Front 2.5" back lift from Supreme suspensions.
Granite Alloy 17x8.5 wheels with +25mm offset, and 315/70/17 BFG ATs.
Had to trim a small piece of plastic (~1/2") off of front bumper. Took about 30 seconds on each side with a dremel.
tdappleman
Greensboro, NC
I'm looking at doing the 3/2 spacer lift with the extended sensor links for CCD. What are you all doing for tires on the 22" wheels? I typically like more sidewall but do like the looks of these wheels. I'm thinking the Toyo A/T3's or the Falken Wildpeak A/T3W.
RenoMoto
Reno, NV
Here are a few pics of my '16
My friend made a nice video about the truck HERE
Currently lifted with spacers - its the only bolt on option I've found.
I also installed custom rear springs that are 25% stiffer and 1 inch taller.
Currently gathering parts for a Raptor front suspension kit and custom 5 link on the rear with Fox 3.0 Racing coil overs.
Should be about a 3 inch lift from stock with 12 inches of travel front and rear.
Will update when that project is done. (Hopefully!)
Baja Kits Ford F-150 Pre Runner Kit
Fox Raptor 3.0 Internal Bypass DSC Coil Over
The money pit never stops - But it sure is fun,
Mike
Southbayaaron
Pacific NW
I’d ditch the 22s if you plan to off road at all.
tdappleman
Greensboro, NC
Oh I understand that.... but I usually off road in a 74 Bronco. This is more for the look and occasional bad weather going skiing or something. I have a set of 18" factory wheels but I like the look of the 22s. Was just wondering if anyone had used them at all - my tire options would probably stay the same no matter the wheel size. i just sold my auto shop and have had great luck with them.
2K9U324
CA
Mike do you have a link / source for said springs ? Saw the video, your truck is exactly what I'm going for. Great job !
kldq8y
kuwait
i want to share with you guys the Readylift 3/2 on my 2015 4x4 EL
i also replaced the old shocks with Bilstein 5100
they can extended by 1" more , but i just keep them on 0 and here is how they looks
my next step will be a bigger tires , its my daily use car so i will go for 285/70 i guess
or maybe 295 depends on market here :)
1oldtimer
Va
View attachment 41651 View attachment 41652 View attachment 41653 View attachment 41654 I put Bilstien 5100 all the way around with fords latest revision of spring which has a bit more lift. I am running Fuel 20s with Goodyear ultra terrain tires. It’s plenty high enough for me and the electric running boards actually have a purpose now.View attachment 41651View attachment 41652View attachment 41653View attachment 41654
Which 5100's are you using? How much lift did you end up getting and how about some info on the springs please :)
sharprd65
