After driving this setup for a couple months, the root cause of
I used the Readylift kit which is supposed to give a 3" front and 2" rear lift, essentially removing the factory rake. Here's a link to the kit: https://www.stage3motorsports.com/6...ylift-3-front-2-rear-sst-spacer-lift-kit.html. I'm essentially running 33" tall tires and only experience rubbing on the front of the driver side power step when backing up on unleveled surfaces. The tires are rubbing the paint of the plastic end cap that covers the power step. No need for cutting or shaving since it doesn't rub anywhere else and doesn't seem to be hurting the tires. Great setup. I didn't want to swap out the rear air struts with conventional coilovers because I like the stability they give when towing. You will be pleased with the setup though.Looks amazing! What did you use?
