Silver trim touch up paint?
Caviar65
Colorado
So I scratched up the front bumper’s silver piece of plastic trim, down to the black base color. Can’t seem to find Ford touch up paint for this color, only seem to carry the primary vehicle color. Any ideas? Thanks in advance!89f61af7fedaef9c1af9c3108a4a7983.jpg
16plati
VA
few options you have:
1) try to either pop that piece off or tape it and paint the whole thing with silver bumper/plastic paint. Ford color pens are only for body colors, not trim
2) stop by stealership and request quote for new piece. Warranty??
3) sand the rough edges and wrap that piece with vinyl, more labor intensive IMO
I’d go option 2 then 1 then 3. Thts just me
C
Caviar65
Colorado
Thanks. Might have to go #2 unless maybe the trim color is the same as Ford’s silver body color in which case I could try some touch-up
mossback
2017 Limited EL
WA state
It’s ghetto, but if nothing else, a silver Sharpie pen actually matches that trim piece somewhat decently. The three options above are all much better, but for a temporary touch-up it works.
scottdm
Western PA
I have the Ingot Silver exterior, and the silver trim piece has a slightly darker color to it. Have you talked with your dealer's part's dept to see if they have touch-up paint available for the trim piece? If you use the Ingot Silver touch-up paint, it will be slightly lighter in color, but it's still pretty close.
Flexpedition
midwest
I'd feel like a entitled millennial cockroach asking a dealership to warranty this.
Here is another bad millennial option: Silver duct tape from Home Depot. Then return the used roll for a full refund. Then leave Home Depot a bad review.
If you can't be without this piece on your truck for a few days while the original one gets refinished, a replacement is part number JL1Z-8419-APTM and they run about $85. The APTM in the part number means it comes Paint-To-Match, so your opportunity to paint/wrap the new piece black to match your Expedition, or maybe a different shade than current if interested.
If off-road is your thing, maybe cut some holes in the old one for some LED lighting, could turn out great.
scottdm
Western PA
Just bumping this thread to see if anyone has found touchup paint that works on the silver trim piece on the front and rear bumpers. My dealer doesn't have a part number for touch-up paint for it and suggested having a body shop color match some touch-up paint. I find it hard to believe that Ford doesn't offer touch up paint for the silver trim strip on the front of an $80K vehicle.
techdude99
US
I just removed my front license plate holder and would like to plug the silver trim hole at the top.
Anyone find the color code?
Thanks!
white01ss
US
I figured I would bump this thread to see if anyone has had success finding this code?
Thanks!
joshuahouston17
Rome, Ga
I just had to replace this part on the front of a 2019 Expedition Limited. The part # on the back of the part is JL1B-17F771-AAW and was originally molded as a silver part (not painted). The replacement for this part is part # JL1Z-8419-APTM and must be painted. After calling Ford Technical Support I found out it is called Iconic Silver and the paint code is JS and the touch up paint code is M7432A...
Hope this helps someone as it took me a few calls to finally get an answer...
lmrichar
alabama
I hope you see this because it's an old post. I'm talking to joshuahuston17. My dealer is trying to match the paint on my hitch cover part. My ride is 2019 Expedition MAX Limited Platinum in the pearl white. The bumper is the silver that you're referring to but they painted the hitch cover and it was a darker silver and looked bad. They now are searching with a body shop to match it. I was just wondering if the Iconic Silver JS and/or M7432A would be the answer?? Thanks
Fastcar
Army
FL
I was about to suggest this. I've used the Sharpie paint pen, then used some old polishing compound and was pleased with the result. Heck, your not repainting the whole piece.
11b4v
Alabama
Behr Premium, Metalic, Soft Iron is a very close match, Home Depot. You might need a clear coat.
