Skar 4500
Newport News, VA
I'm buying this on the 1st of April...getting ready for future upgrades one step at a time...i'll either run it at 4900 rms or 5860 rms when said and done...but initially when I get it it will be at 4 ohms 1500 rms on my current 18" sub...plans is for 2 PSI performance 18" subs @ 3K rms or 2 tantric 18" subs @ 2.5K rms...so 5k or 6k rms...BOOOOOOOMMING!!! for sound offs only of course...lol
SK-4500.1D Monoblock Amplifier
Technical Specifications
•Class D Digital Monoblock Amplifier
•Compeition Grade
•Linkable / Strappable
•4 Way Protection Circuitry : Thermal, Voltage, Speaker, DC
•RMS Power @ 1 Ohm : 4,900 Watts x 1 Channel (14.4v)
•RMS Power @ 2 Ohms : 2,780 Watts x 1 Channel (14.4v)
•RMS Power @ 4 Ohms : 1,500 Watts x 1 Channel (14.4v)
•RMS Power @ 1 Ohm : 5,860 Watts x 1 Channel (16v)
•RMS Power @ 1 Ohm : 7,420 Watts x 1 Channel (18v)
•Frequency Response : 15~270Hz
•Input Sensitivity : 6V~0.2V
•Signal to Noise Ratio : 95dB
•Damping Factor : 200<
•Low Pass Filter : 35Hz~250hz
•Subsonic Filter : 10Hz~50Hz
•Bass Boost : 0dB~9dB
•Phase Shift : 0~180 Degrees
•Dual 1/0 Gauge Power and Ground Terminals
•Working Voltage : 8.5V~18V
•Remote Gain Knob Included
•Line Out RCA Connection
•Recommended External Fuse Rating (450Amp)
•Dimensions : 650mm (Length) x 241mm (Width) x 64.5mm (Height)
$2K amp...lowest I've found was for $1500.......................getting it for $875!!!
tallsville
LA
ok . sorry to thread jack freeway but you 2 know alot about car audio. first can an amp be fixed? MOm used my expy while here and moved my subs. She ripped out the gain control. The connector is now bent into the amp and the connector on wire is missing the plastic holding tab. Can this be fixed? and if not what is a decent fairly inexpensive 1000w amp?
Newport News, VA
Good deal, thats a fun amp. How many runs of 0ga are you doing?
1 run...000 ga...or 0000 ga wire...3 and 4 times thicker than 0 ga...I didn't know it existed until today...met this guy who used to work for DC Audio and he showed me his setup....SUPER THICK GROUND/POWER WIRES!!!
yes they can be fixed...that should be able to be fixed too...if not go with audiopipe...boss...get on fb and search car audio classifieds...ppl are selling some good stuff for low prices...I was about to buy an American Bass 3k rms amp for $400...its a $1K amp new...but I got a great deal on the amp I'm going to buy for $875 and its easily a $1500-$2K amp new...I just like knowing im the 1st to have stuff...my current setup I bought from someone for $450...amp/sub/box...then i got a box built to specs...how many channels are you looking for? I have a Massive Audio amp I'm selling for $150...1400rms
tallsville
LA
im running 2 12's off the amp. the doors are off the radio. not too sure about all the audio stuff. i'll have to look at what the amp is.
tallsville
LA
tma(total mobile audio) which was bought out by jl audio a few years ago.
Newport News, VA
So what r u going to do? Lanzar is coming up as a low budget amp...I suggest audiopipe...how much u looking to spend for new amp? U would have to search for places that repair them
oblivion
Ontario Canada
yes i can be fixed and very easily depending on what it is. does your gain control look like this?
A store like radio shack, the source and even home depot have these connectors.
oblivion
Ontario Canada
Freeway, I have used 000 or 3/0 before and its a Pain in the butt. I can only imagine 4/0. Be prepared to get custom terminals machined.
tallsville
LA
yes it does and thank you. How hard is it to fix the "pushed in" part on the amp itself?
