Slight shuder at WOT
yammerslammer
NKY
I'm getting a slight shudder/vibration just before the gears change when I hold the pedal to the floor. It doesnt matter if I'm just taking off, or if I hammer it while running 55 mph. It almost feels like running over a mild set of rumble strips. I drained the transmission pan and the torque converter and installed a new filter, but the problem is still there. It only does it at wide open throttle.
ELVATO
Orlando, FL
Sounds like torque converter shudder, though I'd think changing the fluid might have helped?
fiveohpoepoe
NC
Add some additive to the differential fluid. I had the samething on one of my 98,s and that helped
Y
yammerslammer
NKY
I changed the fluid in the pan and the t.c. but still noticed it after the first test drive. I drove it all weekend and never had the problem again. Maybe the new fluid needed a few miles to start working??? I dunno....
ghettoracer
Oregon
A couple of questions: Is the shudder coming from the rear or from the front? When was the last time you did a rear diff fluid change?
eastcoasteskimo
Hampton, VA
My "06" does the same thing but the engine light comes on, loss of power and shudder, then after about a min the light goes off and it runs fine. This has only happend twice and both times the same thing happends
dennisspeaks
Spokane WA
shudder?
i wonder if this is my problem, I notice the shudder on the drivers side, mainly when I am taking off.
I will have to find a DIY transmission service and see if that fixes my problem.
