Slow acceleartion
DriverDan
Hey everybody, I just bought my first Expedition, a 2003 4x4 Eddie Bauer. I had it inspected by my mechanic before purchasing, and it has 150,000 miles. I'm here becuase it does not seem that it accelerates as quick as it should. I should note it has the 5.4l. Upon first driving it, I thought it seemed a bit slow, but didn't know for sure if that is just how they drive stock. I looked up the 0-60 times for these models and it seems it should be somewhere in the range of 9.5-10 seconds. When I went out and tested it, I came in right at 13 seconds going from 0-60:confused:. Can anybody help me figure out the reason for the loss of all this power?? The mpg's seem fine so far, the onboard computer reads 13.2mpg for purely city driving. Also, it isn't throwing any codes. I plan on cleaning the MAF, throttle body, changing the air filter, and changing the fuel filter, but I feel as if something else might be the culprit with such a loss of power. Any help would be appreciated!:Rock on:
BIG GREEN FORD
loxahatchee Florida
Sound like you are on the right track. Also it would be good to change spark plugs. From being old the gap in the spark gets bigger so you will need a lot more spark (witch means loss of power)
Newport News, VA
its prob programmed to be slower like i have mine with my programmer for better fuel economy...get the ecu reset to factory and see what that does...then go into further inspection...
D
DriverDan
How would I go about resetting the ecu to factory settings?
D
DriverDan
Would it be a good idea to just go with oem spark plugs, or are there better, more reliable ones out there?
D
DriverDan
Alright thanks, I'm hoping a combination of all of these will help me regain some power!
D
DriverDan
Well just as a bit of an update...I pulled the air filter and it looked pristine, so that is not the culprit. I sprayed some CRC on the MAF, and I also cleaned the throttle body, but it didn't seem too bad. I took it out for a test drive, and it again hit about 12.7 seconds 0-60. All that's left to do is change the spark plugs and change the fuel filter. Do you think those two things alone could be the culprit, or is there something else going on here? I'm not concerned strictly about the 0-60 time, as I won't be hot rodding around, I just want to know where all this power is going! I appreciate the help guys.
JUST4FUN
Admin
Moderator Administrator
Il
Is it starting out in second gear ? try holding it in first gear and shift it manually
stamp11127
Temple, Georgia
FYI - read up on changing the plugs on the 5.4 and have your cuss words handy.
You should start with " What dumb azz......."
D
DriverDan
Unfortunately (or fortunately) I tried this, with shifting manually still came up with the same time
D
DriverDan
Yes like stamp said Its a pain in the ***
So I have heard. Now it's time to decide if I want to bite the bullet and have the shop take care of it, or take the time and do it myself to save the money. And yep, I've read up on all the precautions to take when changing out the plugs
JUST4FUN
Admin
Il
I would deff have a shop do it . one plug breaks off and you need a new tool or a tow to a shop
