My issue is the noises this engine makes when started in these cold temps. Mine gives a whole lot of whirring and slight humming sounds from what can only be described as the pulleys and possibly things like lifters. some of the sounds are on the front of the engine and some are on the sides, close to the exhaust manifolds. Speaking of exhaust manifolds, anyone have possible issues with the cold causing the manifolds to possibly shrink and create gaps. It sort of sounds like slight exhaust leaks when started this cold.
Don't get me wrong, even previous vehicles I've had often had different noises when started this cold, but this one seems more than previous ones.
It does drive well in the snow, but if not in snow mode, the turbos absolutely break the rear loose pretty easily when they spin up.
