I just got a 2007 XLT and did extensive research about the spark plug problem...discovering that they are the most least thought of design irritates me and the possibility of them breaking IN THE HEAD, I mean c'mon! Either way, I took the car to the dealer and found out that the check engine light went on for a bad coil. Coil #4 is going out and I was hoping someone could tell me which cylinder is #4?
In addition, would it be ok to change just the bad coil or should I change them all? I also ordered the broken plug tool kit for when I change the plugs just in case they break.
Should I remove the plugs when the engine is hot or cold? And what about putting the new ones in besides covering them with anti-seize, should the new plugs go in hot or cold engine?
Any information would help and thanks in advance.
