Spray painting 98 expy grill.
socomboy
Memphis, TN
Whats up guys? I have a white 98 eddie bauer expy and I really want the grill to be white. Do you think it is a good or bad idea to spray paint the grill with with krylon spray paint? If so will it look professional or close to it? Suggestions are welcome
Spoon-Man
Mikado Mi.
Its All in the prep.. Just prep it right and put some clear cotes on it so it will last.
nvycrmn
Springville, IA
i spray painted mine black and it turned out pretty good. and i used the krylon. just make sure you prep it good to get all the flaking off. and use even coats. take your time so it doesnt run or glob up.
S
socomboy
Memphis, TN
great. now this may sound stupid but what are the prep steps if y'all don't mind?
nvycrmn
Springville, IA
well since they are usually coated in a cheap layer of chrome dip, they flake. so sand it down the best you can. us an adhesion promoter that you can find at just about any autoparts store. then, spray away. just make sure it is clean before you spray.
ELVATO
Orlando, FL
I'm guessing you have Oxford white paint? Not sure if the white Krylon will match or not.
