Eightiesrock80
wondering when most of you 5.4 owners replaced your original oem starter motor from ford.
I also have an '03 with 265,000+ on it and still no issues. The only real shop time this thing has ever seen was a trans rebuild at around 135,000 (my fault -- fried it reversing up an incline with a trailer) and new head gaskets (oil leak) at around 155,000. I always run Mobil-1, so when they cracked it open, the inside was as clean as the day it was built. Most reliable vehicle I've ever owned.wondering when most of you 5.4 owners replaced your original oem starter motor from ford.
I had a sticking caliper once on my '03. It was the quad seal that was just hard and had no spring to it (the quad seal not only seals the piston, but also helps retract it when you let off the pedal). New quad seals on all the pistons and no problems since. It's an easy DIY job if you're then able to bleed the brakes yourself (also a good time for a fluid flush).I could tell you right now exactly why your caliper is sticking. You just need to replace the rubber hose coming out of the caliper that is going to the metal line.
Head gasket or valve cover gasket?I also have an '03 with 265,000+ on it and still no issues. The only real shop time this thing has ever seen was a trans rebuild at around 135,000 (my fault -- fried it reversing up an incline with a trailer) and new head gaskets (oil leak) at around 155,000. I always run Mobil-1, so when they cracked it open, the inside was as clean as the day it was built. Most reliable vehicle I've ever owned.
Head gaskets. One was leaking oil into the valley. Never had a valve cover leak.Head gasket or valve cover gasket?
I got my truck around 140,000 it’s at 194,000 now I’ve had it 6 years love it. I was upset though when I got it found out the guy never fixed the intake manifold, causing the head gasket to go so I had the heads done and while that was being done. I said let’s do the timing chain and guides since it’s open. She’s a great vehicle.Head gaskets. One was leaking oil into the valley. Never had a valve cover leak.
My friend I have a 2006 Expedition 5.4 Eddie Bauer 214,000 MI still have the original starter I did a timing kit in it and a transmission that's itwondering when most of you 5.4 owners replaced your original oem starter motor from ford.
