Stranded again.
Anerbe
Mi
Overall, later years should be more reliable, minus new tech added within the model lifecycle.
duneslider
Utah
This doesn't sound like a common issue with this transmission, in fact I have not heard of very many issues with this transmission at all. I have pulled my camper up some steep stuff and gotten it hotter than I would like and have not had issues. What ever is going on is not normal. Just replacing the seal is not going to fix the problem, somebody needs to figure out why the seal if failing because loading up with ski equipment is not enough to cause this sort of failure.
29twonine
29twonine
Colorado
Yeah I agree and now that the seal has gone twice that makes more sense. I’ll let you guys know what I find out from the dealer, hopefully by the end of the week.
lurch
Boulder, CO
I have been pretty frustrated with the reliability of mine and started looking at the alternatives. I was left pretty underwhelmed with the competition. All of the GM engines in the Tahoe/Suburban have some pretty serious issues right now. The gas engines had a bad set of lifters/rods that are causing engines to need rebuilds or replacement within the first year and sometimes days of purchase. The baby diesel has an issue where it won't even start sometimes, there is a software fix that causes it just to crank longer but that does not fix the mechanical problem inside the engine that is just degrading with use. The new Toyota turbo engine is causing serious issues in Tundra and that will likely be the same story in the Lexus LX and Sequoia. The Jeep Waggoner has Stelantis quality issues and while it is rated to pull 10,000lb it has a payload so low that you can't use it and bring your family.
retired_chemist
NH
Back in the day, 1982, I bought a Chevy K5 Blazer. It was built on the Monday after the Christmas - New Year shutdown. I know this from the paperwork I found in it after I took delivery. In the first three months I owned it, it spent one month at the dealer for many problems. I went to arbitration over it and the zone rep said they would make it good. They never did, and I vowed to never own a GM vehicle again, and I haven't. My Fords have problems, buy at least Ford makes them good.
Team_Z
Wa
All manufacturers are hit or miss. Especially now a days. I’ve had 15 F150 platinums since they came out in 09/10. I’ve had good ones and I’ve had bad ones. I’ve owned GMs 2 that GM ended up buying back one right after the other! Lol. I’ve had German cars, same thing good ones and bad ones. I managed a few Japanese car dealerships and the same good ones and bad ones (never buy an early build 19 Camry or rav4)
Now I did have a 2018 Land Cruiser that I put over 75k miles in roughly 2.5 years and it was a beast! No problems. I drove it like I stole it, put it through its paces. But the design was outdated.
I’ve come to one conclusion early on. anything that is man made, it’s quality very dependent on how the people felt that day. That’s saying “this must have been a Friday car” is unfortunately true. Learned this from being in the industry for 15 years and having family that work at Ford plants.
The grass isn’t always greener on the other side. Just buy what you like and cross your fingers.
ROBERT BONNER
Denver, NC
BTW, does it seem strange that we had the same transmission leak almost exactly a year later at the same spot on the interstate (going up I-70 in Colorado towards Eisenhower Tunnel)?? What are the odds of the same seal going out after no problems after one year???
Just out of curiosity what seal is going out? Is your Expedition 2wd or 4wd?
Anerbe
Mi
Agreed - I love how Toyota / Honda still used old dash clock displays and shifters - the interior could be mistaken from 15 years ago.
You get the reliability at the cost of modernization. Always putting new design / tech in a car will lead to some reliability issues.
29twonine
29twonine
Colorado
So the dealer thinks the transmission was overfull, but they're going to pull the pan off and "check around" to see if they can find anything else that may have caused this issue twice now. Before both of these "incidents" we did have the valve control body replaced so who knows. Sounds like I'll hear back in the next day or two if they find anything.
It looks like there are a couple of 21 Platinums available in my area, may just trade this in so we don't have to worry about it again and cross fingers we have better luck with a new one again. I'll keep you guys updated on what the dealer says when I hear from them.
29twonine
29twonine
Colorado
It's a 4wd and supposedly the seal from the transmission to transfer case. This other dealer says that this time it seems like it was overfull and "pushed the transmission fluid out" but they didn't specify where this time. (post above). Waiting to hear more.
Team_Z
Wa
I am willing to call BS, over filling it to the point that it “pushes” the seal out you would have had issues long before a year later. That much fluid would cause drive ability issues long before now. They are giving you a generic BS response. Someone doesn’t want to have to explain that the 10r80’s are junk the first year they came out. It’s mostly Fords software that cause problems. They just about got all the bugs out now.
Boostedbus
Maryland
I think the transmission clearly has a pressure issue going on internally. Why did they replace the valve body before?
duneslider
Utah
I also think that is a BS answer. I don't believe the 10r80's are junk but I do think something is going on with yours that is not normal. Valve body and torque converter are where pressures are at. I wonder if the torque converter is bad? I'm not transmission expert.
29twonine
29twonine
Colorado
Well I'm of course still waiting to hear back from them!! No updates but I agree that overfilling is probably but the culprit!
Hopefully next day or two I hear back to see what they say.
29twonine
29twonine
Colorado
Just following up on this thread. We've had it back for a couple weeks now and they are saying it was "overfull." Whatever. So far no problems and it shifts pretty good since they changed the fluid and filters.
Regardless, I just ordered a new Limited Stealth 304a yesterday. Someone else will probably get this one and not have any problems whatsoever, it's just been bad luck for us. Got the new one at invoice and with the high trade in value still, I don't feel too bad about the whole thing (except no dvd system for the kids)
Now the waiting game for the new one!
