Came out late last night in the cold, and after starting up (starts fine), the hvac was thumping like one of the door motors has broken it's shaft to door connection, both brake warning lights are lit even though the fluid levels is okay (and I had the brakes/disks/hubs all replaced back in June 2018), the traction control light goes on and off at intermittent times even if I'm not moving or driving straight on dry asphalt; tapping the traction control switch doesn't change anything. Then the navigation stopped working and says a fault has occurred.
Is my main computer dying or something? I tried an OBD2 plug in to the connector below the steering wheel, but neither mine nor my friend's will connect with our blue tooth phones.
I'm worried about trying to drive home tonight (christmas night).
