I have a 2011 Expedition and I noticed that when I go through the car wash the sun roof leaks with the high pressure water. I understand that the sun roof is "supposed" to leak some and there is a water drain. That seems to work ok. It's when this high pressure water comes down, it squirts through the seam and on to the interior.
Looking at the top of the sun roof, I noticed that it "sags" in the middle. Enough that if I push down on it a little, I can clearly see how the water gets in.
So my question is, is there an adjustment that will make the sun roof come up tighter? I can push on the inside and almost stop the leaking. So I think the seals are good, it's just the sun roof is not coming up all the way, but only in the center. Below is a picture (hopefully, I never attached anything before). You can see where it is bowed in the center.
Any ideas are appreciated.
Thanks,
David
Thanks,
David
