Sunroof leak
finnesse357
canada
Hey guys, I’m new here just joined the forum.
Initially I was looking to see if there were any fixes for the park lights ( I checked all fuses and the wire running on the passenger side floor). I couldn’t seem to find any blown fuses but when I looked further it seemed I did have a blown fuse potentially because the sunroof is leaking like crazy down near the fuse panel. Anyone else have this issue? Better yet any fixes on the sunroof leak? Thanks
Trainmaster
Old School Member
Rockaway Beach, NY
Welcome here! Clear out the drain lines for the sunroof. You can search this site for many discussions on this. Also check that the bottom of your windshield's not leaking on the fuse panel.
Yupster Dog
Super Moderator
Super Moderator
After you Check what Trainmaster said,
You can do a VOLTAGE DROP TEST. a lifted ground can also be suspect.
neogenesis
Wa
Sunroof leak Found- MUST watch if you have a leak!! May not the drain tubes!
Seal - Ford (5L1Z-7851884-AA)
Install Video:
