cudaz101
Boost Temps
A remedy for high intake charge temps is Methanol Injection. I personally like the Snow Kit among whats available. This will enable you to run a few more pounds of boost without ill effect. It can really clean things up.
An air-air intercooler of course will help tremendously as well. The Meth injection and A2A IC combined would be key in making big numbers.
Also...And an SCT Tuning package would work wonders as it is one of the most common among tuners and has alot of control.
At bigger power levels you could start pegging your MAF as well.
Lightnings can make big boost & power numbers without gernading because the stock internals are desgned for boost. The Expedition rotating assembly is MILES from a L-Rotating assembly. I do think however that the 5.4 EX eng. if tuned properly, will last at higher boost levels of say 10-13lbs.
