SuperChips and disabling fuel system?
rex450se
Independence, MO
I just got an older SuperChips 1715 for my 03 and I'm trying to get it all hooked up. It says I need to disable the fuel system. I can't seem to find the auxiliary fuse box so I can pull the fuel pump fuse? Or is there some othr way that you guys did this? Thanks in advance.
Victor
rvm1
Manila, Philippines
On the 2004 it is located on the passenger side fire wall. I pull the middle plug / harness. There is a gray lever bar on top of the harness that you pull to unlock / release it. Be sure to push the lock back after tuning. Hope this helps.
Sent from my HTC Sensation Z710e using Tapatalk 2
rex450se
rex450se
Independence, MO
That was it! Thanks. Between a Chilton's, Hayne's and the Owner's Manual I could not find the damn thing. Thanks you very much.
Victor
