superchips on 2003 eb
anjray
NJ
I have a superchips max microtuner and wondered if anyone has had much power/fuel economy improvements tuning an '03 5.4 expy. Also, what is the best way to disable the fuel system? I read that punching the inertia fuel pump switch works but I'd rather not.
Newport News, VA
i have the vortex 1950 by superchips...if i put it on gas saver tune i get great gas mileage...and if i have it on performance...the power, fast throttle resposonse is outstanding.
A
anjray
NJ
oh nice, any thoughts on the best/easiest/fastest way to disable the fuel system?
Rockunlimited2
Omaha
Why? if you need to pull your fuel filter, just disco the batt cable and flip on your lights to drain any left over volts and then remove the filter, it will only shoot a little out when first discoed.
A
anjray
NJ
when i plug my superchips max microtuner in, it says disable fuel system. when i had my 2000 f150 5.4 i would just ignore it and it would let me tune anyway. Now with my 2003 expy 5.4, if I ignore it, it won't let me tune. It says "cannot tune because fuel system has not been disabled." It's superchips model 1715 which is supposed to be compatible up to 2003.
A
anjray
NJ
On that note, any ideas on the best way to disable the fuel system? The fuel relay is #303 and is "not a serviceable relay" according to the manual. Also, the inertia cutoff switch is only visible enough to push the reset button. To unplug it, I would have to remove he whole rear panel.
WHOISMOOTOO
Dallas, TX
Ouch, i'd contact superchips and let them know your having problems and they could help you a little more
A
anjray
NJ
A
anjray
NJ
I have already called superchips and the consensus was that I need to take the "non-servicable" relay out or disconnect the harness on the bottom of the inertia switch. I was just hoping someone would have a less time consuming way of doing it. Does anyone else disable the fuel to tune?
A
anjray
NJ
Thanks for your help guys. Really appreciate it. I think im actually going to update my tuner. I'm leaning towards the sct sf3 which has 3 canned tunes and ability to get some custom tunes later if i want. Any thoughts or experience on which tuner would be ideal? Also, not sure if it makes a difference but truck has a brute force CAI and throttle body spacer.
A
anjray
NJ
yeah, mine just has the reset button. Hopefully with a newer tuner, i dont need to disable the fuel. Didnt you say you dont disable yours?
A
anjray
NJ
That's what I'm going for then. Thanks for your input.
