suspected intermittent fuel pressure drop
AZ Moose
Flagstaff, AZ
2005 Expy ELT 5.4l been battling this for a year now, many new parts, problem persists. Engine cranks fine but it acts like it is fuel starved. Doesn't happen every time, 1/2 to 2/3 of the time. When it fails to start I turn the key off, then to run (just short of crank) wait 5 - 10 seconds, crank again. This usually starts the engine in 1 to 5 attempts. Parts replaced: Fuel pump entire, fuel pressure regulator on fuel rail, fuel modulator? electrical on top of frame rail, 3 fuel injectors. Symptom persists after installing new parts. No evidence of a leak. Chevron gas, fuel injector cleaners, symptom more pronounced in cold weather. about to trade this truck although I like it. No details on pressure readings, no codes in computer, no vacuum leaks.
:think:
rice_classic
Home
I would get it hooked up to a proper diagnosis machine, not just a "code reader" since you're not seeing any CEL anyway. Usually a proper diagnosis can find things like intermittent computer failure, maf sensor failure, intermittent spark failure etc.
Lostneye
NY
I agree to try and get it hooked up to a monitor to try and better diagnose.
But I will suggest also looking at the fuel pump driver on the driver side frame rail. From the factory they sit flush against the rail and the dissimilar metals tend to corrode faster than they should. The new ones have spacers to prevent this. Still look to diagnose before adding more parts.
05expedeb
Medford NJ
Good advice but if you read the original post you would see he has replaced the FPDM expect he called it a modulator. Also the FPDM is more prone to corrode in states that use salt on the roads not in AZ Although anything is possible
A
AZ Moose
Flagstaff, AZ
Thanks for the ideas
Correct is was the FPDM that was corroded and replaced but the problem persists. Can anyone recommend a fuel pressure gauge? And where does it connect to the vehicle? I realized today that I never replaced the gas cap. If it is venting incorrectly could that cause this problem? Stamp11127 I have no reason to believe that it is electrical. Unless the computer is doing one really odd thing, but I will have the dealer run a diagnostic soon.
Thanks guys!
05expedeb
Medford NJ
In reading abouts the parts you replaced I didn't see FUEL FILTER hopefully you replaced it but if not maybe you should. Since you replaced the FPDM I would recheck the connector to make sure all contact areas are clean and making good contact
A
AZ Moose
Flagstaff, AZ
Thanks for the video reference, that helps. The fuel filter was replaced a year ago. I picked up a new one tonight as well as a new fuel cap. I will update this weekend. Thanks all!
mystik
If this is happening intermittently, then you turn off the key, wait a few minutes, then the truck starts. It sounds to me like the security system might have an issue. When you turn the key off, it seems like your resetting the PATS system. I would look into either the key chip or the PATS system its self. Just my opinion
A
AZ Moose
Flagstaff, AZ
Solved!! It wasn't the PATS. The dealership found a fault in the fuel relay. The fun part is that means replacing the entire fuse box. It took them a few days to get the right part in but it works now. $800 repair. All of my keys had to be reprogrammed since the whole system rebooted. Glad to have it fixed. At least I've got a crap-ton of new fuel parts in it. Thanks everyone!
stamp11127
Temple, Georgia
Did they give you the old fuse box by chance? A few of us on here can show you how to modify and upgrade it for a higher amperage relay.
Ed_Strong
SWFL
Any chance this could be posted for all to see, matbe as a sticky post? I would like to know whats involved in the modifying!!!
Mine started burning the PCM Relay and I ordered the Fuel Pump Relay from Digi-Key and replaced it last week and so far it's working great!
But when I removed the old Relay from the PCB board it wasn't melted or burned or smelling like all others have commented...
So now I'm not sure if this repair fixed anything or left things the same... time will tell I guess!!!
If this repair ends up not helping then my next move is to "upgrade it for a higher amperage relay" like you mentioned!
