So I swapped out my rear air springs/struts for OEM coil strut assemblies on my 09 Exp Max.
I removed the lower shock bolt and lower control arm to frame bolt and then the 3 bolts on top of the strut assembly and then re-installed the coil struts in reverse order.
So rookie question on the alignment. Based on just removing the lower shock bolt and lower control arm to frame bolt I don't think I need to worry about an alignment do I? The truck seems to sit almost exactly the same height as with the air springs.
Any thoughts?
Thanks
Any thoughts?
Thanks
