Sync 4 update manifest Error
alhasawi
kuwait
Hi
I was wondering if anyone can help me with my sync 4 with maps update to APIM module update
Everytime i update that module using FDRS it gives me manifest error
People told me to look for Ford software engineer to fix that issue unfortunately here where i live we have none
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Hi
Fully licensed version of FDRS? What cable are you using? Need a screenshot of the exact message, and are the other modules up to date. Normally Sync 4 is a USB Drive driven up date from FDRS.
alhasawi
alhasawi
kuwait
My FDRS is fully licensed and its up to date i am using mongoose cable and all the modules are up to date and i know the APIM is a USB drive once the app asked me to remove the USB and put it in the car i do so and once i do that i get USB error
I live in the middle east
I think it needs a manifest to overcome that error
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Yes, but FDRS should generate that Manifest. Try a different USB Drive. I have had the best luck with ones formatted FAT32, or at minimum EXFAT. Also, don't use huge drives. Also, don't use an external HDD or SSD. It needs to be a flash Drive. I typically use a 16GB or 32GB PNY USB 3 Flash drive.
alhasawi
alhasawi
kuwait
It wont generate that manifest in the middle east only in the usa thats why i am looking for someone to help
alhasawi
alhasawi
kuwait
Could you check ur private msgs pls
edyk1986
