Tachometer Info - Platinum EXP
Greyfox
MY tachometer (2018 Platinum) has a vertical area that indicates the gear you are in when driving in MANUAL mode.
When in Drive there is no info in the area - is that the way it is supposed to be? Cant find any info the the manual. HELP.
PS: Have the car 1 week now - LOVE it !!!
edizzle
Cashiers
Press the minus button once while in regular drive mode. It will permanently display the gear column.
edizzle
Cashiers
Do you want to see the gear display or not? If not, do nothing. If you do, press the minus button once.
dlcorbett
Air Force
tx
Lol calm down e...those are 2 different post from 2 diff ppl
edizzle
Cashiers
i swear i didnt type that to sound like that!! when read, it does give off an assholish vibe!! and i did think it was the same poster!!
G
Greyfox
Didn't read it like that :) Thanks for the info - by the way how in the Heck did you ever discover to "press the minus"
Randy Schmidt
Illinois
What I meant to say was... Mine is on all the time. If I didn't want to see it, would I push the minus button to turn it off?
aggiegrad05
North Texas
Manual in the section on the Transmission
Progressive Range Selection - PRS
Progressive Range Selection gives you the ability to lockout gears from the automatic shifting range. This may provide you with an improved driving experience, for example, in slippery conditions or when experiencing a steep slope.
With the transmission selector in drive (D), push the – button to active PRS. The available and selected gears are indicated on the instrument cluster.
All available gears display with the current gear indicated. Push the – button again to lock out gears beginning with the highest gear. Example: push the – button twice to lock out 10th and 9th gears. Only the available gears are displayed and the transmission automatically shifts between the available gears. Push the + button to unlock gears and allow the transmission to shift to higher gears. The transmission shifts automatically within the gear range you select.
Randy Schmidt
Illinois
That kinda cool...
twernst
Manahawkin, NJ
2nd Above -I had to read manual too in order to discover the above. I leave mine off most days. use the + to switch the screen on and off ans the - does same but more as noted above.
