unpredictbleforce
Hello forum,
I was doing a timing job found cyl 4 (passenger) intake roller was bad and damaged the lobe on the intake. I ordered new factory cam to replace. i noticed when i removed cam my head journals have journal bearings which means previous owner rebuilt the head. now with the cam im concerned with journal diameter cam journal diameter etc. So i took the readings and it is as follows
head journals with bearings
27.34 mm
head journals with out bearings
29.38 mm
old camshaft journals as i have not received new one yet
28.43 mm
what should i do as im off by 0.95 mm specs says .001 to .0003
27.34 mm
29.38 mm
28.43 mm
