I have a collection of oil and coolant sitting in the valley between the heads and when i'm running the engine it smokes quite a bit and some drips down to the ground making me think I have an oil leak. This fluid is from the tear down not a leak. It pooled when I took the valve covers off and ran it without the restrictor to see if it was getting good oil flow and the coolant when I took the upper radiator hose off.
Is there a recommended way to clean off the top of the engine without causing issues? It's coil packs not cops - so I figured if I just put the hose under the intake and turned it on slowly I could flush that out without flooding the spark plug wells but wanted to be safe and ask the experts.
I also don't have a shop-vac to use to suck it out, nor do I have an air compressor to blow it out.
Any suggestions?
Any suggestions?
