I'm having some problems figuring out the tranny temps using my Torque Pro app. I've loaded the Ford Custom PIDs, and when I select the Transmission Fluid Temp Methods that return values, I get one that produces -32ish degrees, one at 59 degrees, and one that just mirrors the coolant temp. I'm guess there is a problem with the formula for the first two, but I don't know what it should be. Has anyone run into this or know of a solution? This is the only value that I'm having trouble with.
