Traction Control Issue / but unique.
Discussion in '2nd Gen - 2003 - 2006' started by 04ExpeditionEB, Dec 15, 2014.
  1. 04ExpeditionEB
    04ExpeditionEB Active Member
    47
    27
    Nov 26, 2014
    Bristol PA
    Ok so last I posted, i had Advtrak and ABS on my dash, had codes pulled, was told C2777 and C2778. All the sensors appeared to be functional and passed test. I was then told I had no option but to get the ABS module reprogrammed at the dealer (as its dealer option only) to clear this. well a week later (still didnt get re-programmed) the AS indication stays off, Advtrac does not show warning but the traction control indication is constantly blinking all the time. If I turn off advtrac while in park it stays off until I hit about 20-25MPH. then I get advtrac off/ check advtrac. the center consoled swith still works as normal, if I push it It illuminates (OFF) I push it again and the light goes out but there is nothing on my command center to show its disabled. I run the test and it shows (check advtrac) until I turn off the truck and restart it.
    So I'm stumped as to what could the root cause be?
    Can the brake shoes be the root cause I know they are low (and tons of brake dust) be causing an issue?
    Whrere to start as I cant get a code to pull
    No googeling has assisted in finding a cause or answer.
  2. 04ExpeditionEB
    47
    27
    Nov 26, 2014
    Bristol PA
    Bumping..seems to have been lost in the shuffle.
  3. nikola.kz
    nikola.kz New Member
    Feb 6, 2014
    Kazakhstan, Almaty
    hi where was problem in your story? have the same codes cant find answer
Share This Page
