98EXPY 5-0
Did any of you guys install these trailing arms yourself without a lift? I need to do my lowers and I'm gonna do the uppers as well. I'd prefer not to have to pay to have it done if I can do it on the ground.
Do the nuts also have to be class 10.9?
My thought was to support both sides with Jack stands under the frame and let the axle hang. Then use a jack to support the side I take off? Working one side at a time?
Also, are there any tricks or problems with the uppers? I haven't found too many people saying they did the uppers.
Yes.
I just lifted one side at a time. The axle did swing/twist away from the truck slightly when the LCA was removed. I don't think it will matter much if you do it your way, but you'll want something to be able to pull the axle back into location.
I haven't replaced my UCAs yet, but it will probably be done before too long, along with the track bar. Their design isn't nearly as problematic as the LCAs and the material is much thicker.
