I to need to build a set, my pass upper bar is very badly bent from a wheeling incedent, not so sure on the steel block tube, thinking round with adjustable links
I was also considering doing this. Mind sharing the tubing dimensions you used? I see pmt using 1.5 x 2 rectangle tubing, but I don't know what the end bushing dia/gauge is.
When I have the time and money I want to make a set that are ajustable (up to 3") with round tube.. But they will work for now.. Thank You for all the compss..
