Transmission cooling lines
Boston MA
2004 expy 168k I noticed the trany line leaking and decided to change them.
I ordered the set from Dorman only to relize that it's missing the radiator to cooler hose which No one stocks. The quick connect for the cooler were so corroded that the lines were not coming out..and I can't find thoes fittings except the dealer.. in the process I must of touched the front brake line and I'm glad I did because it just crumbled. Add break lines to the process. I went to bleed them and I need rubber hoses also.. when it rains it pours.
M Bennett
